Discuss ethos 7920 multifunction tester in the Electrical Tools and Products area at ElectriciansForums.net
Anyone had any knowledge of this tester...i had mine about two years and found it great , then one day i noticed ze came out 0.8 ohms everytime.
All other tests work fine including zs..but anytime i read ze it reported 0.8..rang the company and basically they did not know why but of course offered to check it at cost.
But what i also found is if i set up a socket on a lead for ze and plug the unit into the socket it then reads a acceptable ze..crazy...anyone ever come across this with the machine ?
how can you measure Ze at a socket?
you get a socket with a small lead , you disconnected main earth and connect it to the socket earth , you then connect the phase and neutral to the incoming main tails and plug the tester into the socket...its exactly the same but without leads....any electrician could work that out surely
That would be Zs, not Ze.
Reply to ethos 7920 multifunction tester in the Electrical Tools and Products area at ElectriciansForums.net
Hi guys, Had an issue at a recent survey where doing a quick check and found we had pme with a reading of 0.44 ohms. Called the network and they...
HI, I bought the TIS MFT PRO from CEF, nice touchscreen etc, so in the future I could add on the EV dongle and have a fancy case and tester etc...
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
I forgot I had a Di-Log 9803P so called '17th Edition Tester!?', it was a rash ebay purchase a long while ago intended as a spare, and I discarded...
