Hi I have had a free bp chargemaster home charger installed as I have purchased a new car. It hasnt worked since it was installed, when I first tried it, after a few minutes my Mercedes shows an error and stops charging, the voltage detection unit that was installed instead of the earth rod as it was in garage made a clanking noise every few seconds so i shut the charger off. Second visit from electrician, tried another charger , apparently it did the same thing, the car worked fine on 16amps but same problem on 32amps, was told it was my new car. So I tried my car at my neighbours charger which is a different make it worked fine, I got my neighbour to try his golf at mine, same issue. I tried my car at 4 different public chargers using ac 7,4 kw chargers and worked fine. So third visit from electrician, installed earth rod . Car charged for about 20 mins which is longer than usual and then switched off, now it switches off after few minutes, so same issue.
I feel its the inferior charger, maybe its the firmware? When it did charge today for a few minutes it tripped the upstairs light circuit, at that point there was no one upstairs and no one was trying to switch lights on, i have since tried to reset the fuse switch but it instantly trips, i have removed all the bulbs from upstairs but same issue. The fact that my circuit board was disturbed I feel theres some loose wiring left ? it can’t be a coincidence. And finally the electrician has left a few holes in the fuse board, isnt that dangerous? Shouldnt there be blanks in there? there were blanks previously. So as you can see i have a few issues.
any thoughts from experts? Thanks in advance
