Discuss extending ring main in the UK Electrical Forum area at ElectriciansForums.net
Remember that it's a notifiable job...
Why? Kitchens are no longer a special locationRemember that it's a notifiable job...
I've got a twin socket above where a sink will go, the cable drop is from the ceiling, the socket needs moving 2m to one side. Is it ok to snip the two ring cables high up on the wall and fit two single outlets as a means of connecting new longer cables?
unless you are in walesWhy? Kitchens are no longer a special location
If you can't access from above and the only option is to fit two single sockets for connection purposes, why not just fit a single back box and join the cables in there and use a single blank plate. Not pretty but better than two (wasted) single sockets.
Jay
Yes some ceiling access is possible but any connections need to be accessible which I why the plan is to fit exposed boxes or better still your suggestion. Presumably that would mean crimped connectors rather than screw down connectors?
snip them somewhere high, but instead of burying in the plaster or tiles enclose them in a double box and cover up the connection with a blank plate.
not a bad idea, it's a utility room, there will be a shelf high up to hide things so a blanking plate would be fine. Would that be Wago connectors inside then or screw down type? I can get into the ceiling mind, so MF JBs would work as well I guess.
Bloody hell didn't know that, shows how much I know about domestic install...Wales has a different version of part p
Reply to extending ring main in the UK Electrical Forum area at ElectriciansForums.net
