Discuss Extractor/Isolator Help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
K
kennyjb
Hi there
I've been asked to install a new extractor fan in an en-suite bathroom the fan is to be installed in zone 3 so I can get away with a 230V fan
I normally wire extractors with a 3 pole isolator and usually with over run timer but the customer just wants the fan to come on/off with a seperate switch and doesn't want an isolator above the bathroom door.
I know its common practise to fit an isolator to fans with a permenant feed and switched feed for the overrun (maintenance purposes I believe) but is it ok to take a feed from the light and wire the fan 3 plate, simply taking another switch wire to the current light switch and change the light switch for a 2 gang switch ( the switch is outside the bathroom in the bedroom and I have to install an RCD the the upstairs light circuit as its currently on a rewirable board with no protection just in case anyone asks
sorry for the long thread folks just wanted to be clear with what i'm doing any answers would be greatly appreciated Kenny
Hello Kenny
17th Edition says that all products to be installed to maufacturers instructions, and i'm guessing that in the fan instructions. It asks that the fan be wired via a double pole switch with a 3A fuse.
Mark
If its in zone 3 why don,t you put the 3pole isolator next to the actual fan if he does not want it over the bathroom door, at least you still have means of isolation to fan if need be.
Hi there
hi there
if you do install it does it need a feed from a light switch to allow it to over run ie connector block in the pull switch and small sliding switch built in it
i have seen these in spain but not over here:)
anyone else seen them ????????:confused:
might have been a local bodge so not really that sure
cheers
Reply to Extractor/Isolator Help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
I've installed a replacement bathroom extractor fan. Pic on the left is the old one. Pic on right is the new one. Wired the same way but the fan...
