Discuss Finished a rewire today. in the UK Electrical Forum area at ElectriciansForums.net
Dave OCD
Mentor
I'd forgotten how much hard work rewiring can be although this was strictly speaking a partial one, just the original house which had a single very dodgy rubber twin for all the lighting and a slightly larger and equally dodgy rubber twin [with a separate bare stranded tinned copper earth !] feeding umpteen sockets via loads of underfloor JBs and on a 30amp rewirable fuse. The rear kitchen and bathroom extension all done in PVC T&E tested out fine thankfully and was reconnected. TNS supply with a Ze of 0.2 ohms, very good- old lead sheathed cable though.
Everything went really well and the customer is very happy.
Here's a pic of the Hager board I did today, no RFCs at all. :)
nice job. what a pity hager leave exposed copper on the RCD tails though.
Nice job Dave.
Out of interest, do you always fit the 5+5 dual RCD Hager CU rather than the 10 way high integrity?
Reason I ask is wholesalers seem to like stocking the 5+5 and not so much the high integrity unless asked for. I don't really see any benefit in fitting the 5+5 over the high integrity as the difference in price is around £3. If you then want to maybe run a sub main to an outbuilding you can't then 'separate' it from the RCD's in the house.
Nice install Dave, you've got those Hager boards down to a fine art. Let me guess the lad was pulling in all the new cables whilst you were prancing about with the CU?;)
Thanks Will:) Haha not quite, I was doing everything while he dawdled along generally. :D Very nearly boxed a cat in under the floorboards yesterday.:D
Reply to Finished a rewire today. in the UK Electrical Forum area at ElectriciansForums.net
I do seem to pick only the weirdest properties to inspect... Victorian terraced house today - with up front RCD to a Wylex fuse board and main...
I visited a client about a week ago, an elderly couple complaining that their lounge, hall and landing lights were all flickering simultaneously...
6K
Hi all, I am undertaking a partial rewire of a house that a client is needing to do quite a bit of surgery on as tenant just left and what a mess...
B
Here's one that'll make you laugh then cringe,I was doing a replacement RCBO consumer unit for an old wylex rewirable fuse unit on a TT system...
4K
Engineer54
E
G
Many thanks to nickblake for originally posting this in a thread. Paper Paper insulation From the WW1 era Very rare now in domestic wiring...
27K
Stroppy
