Discuss Fire alarm break glass in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
i=p/u
Have to move fire alarm break glass , don't know if enough length on cable,
do I have to use steel enclosure for connections if extending?
if I buy new surface break glass unit does it have to be same type, is there different types?
James Stuart panel, must be 20 years + since I`ve seen on of those......You will also need to protect the cable drop to the call point, any standard 470 ohm call point will work...As above galv 20mm trough box to terminate with crimps
Reply to Fire alarm break glass in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
We have a domestic fire alarm system in some leasehold properties. The existing BRK alarms are no longer available in the UK. These alarms/system...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
