J
joe_berks
Hello everyone .
I have recently started a new job which involves testing fire alarms, and the subsequent remedials, mainly in pubs.
I'm a sparks with 2391 and 17th and I've done it since I left school, I'm 28 now . I hadn't had much to do with fire alarms before now , but I find the testing side fairly straightforward as long as you have the codes etc . My question though relates to the smoke heads ... most of them are menvier , cooper or jsb . But they all seem to have different connections that confuse the hell outta me , even though its only two twin cables ! Are all smoke heads interchangeable ? I dont know where I'm going wrong , I change the smoke head for a new one and follow the diagram that comes with the detector, but it sometimes shows fault on the panel after I have fitted it ?! And also where does the EOL resistor go because I have seen it across L's, L+N, and N's
I know someones gonna start saying I'm going to end up in court etc because I'm not a fire alarm engineer but all I can say is I am believe it or not a competent person !
Any input would be much appreciated .
