Discuss Fire alarm what is this? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Doomed
Called to a hotel where the spark doing a refit took down something and then said that he had no idea what it was so they better call someone else.
I then got called in and I have no idea what it is, apsrt from its the end of line on the fire alrm circuit.
Looks like an old heat detector. It has been painted, if you scratch some off you will probably find the dome is metal.
Old heat detector (not been made for around 20yrs plus).If you are replacing it make sure you check the cable as it could be 30-40 years old.
Reply to Fire alarm what is this? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi, I need to extend a fire alarm, the panel is a CTEC CFP 2 zone one and currently it has a couple of apollo alarm sense sounder bases/heads on...
4K
