A
amckay
You know the pink expanding foam plumbers use for fireproofing holes etc is it OK to use around a hole with a cable run through?
The site I'm on are using it but our supervisor is off today so will check on Monday. I've had a read of the info on the can and nothing is mentioned. I know the yellow expanding foam mustn't be used as it degrades the cable but wasn't sure about the pink fire rated stuff.
