Discuss first for me in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
the pict
Mentor
At a recent job, I found that the timber back board the CU was fixed to was totally infested with woodworm to the extent that the CU will eventually fall of the wall, weird or what never had an insect related job before, C2 if it was a inspection I suppose thoughts anyone
Pict
you neeed to rectify that situation immediately. can't have woodworm being electrocuted willy-nilly. what will the RSPCA think?
Whilst a valid point, I don't think it poses IMMEDIATE danger, so I would code 2
It would obviously be down to the engineer on site, but I'd agree. I've always worked on the thinking that if you can touch it and get a shock or is showing signs of thermal damage it is a code 1 (common sense to be applied as well.)
There is no danger in its present state so it is not a C1, however it is definitely a latent defect so it would be a C2. Further investigation may also be required to see where the little fellas are coming from!
Reply to first for me in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Recently visited a new build to do a very minor job and spotted a few dodgy looking items so Client asked me to do an EICR. Following items I...
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
Morning all So the site I'm based at recently had some work done (think partitioners). This package of work included electrical. This was...
8K
