Discuss Fitting off spd in the UK Electrical Forum area at ElectriciansForums.net
Ok how does that work. ? As I’ve put one in another fuseboard for his air con he’s had fittedNo. You can add an enclosure with an SPD to cover both
As @pc1966 says there is a length of you need to be under for it to be fully effective.The spd needs a live neutral and earth, normally connected after the mainswitch in a Cu, but there’s no reason it can’t be connected before.
you’ve already put one in? Then it’ll protect both if both main switches are on
Reply to Fitting off spd in the UK Electrical Forum area at ElectriciansForums.net
