Sorry fir the length of this.
Am adding some lights and sockets to existing circuits in a SP board. And providing bonding to metal oil pipes coming into this workshop from underground.
They have a diesl SP generator supplying ‘esential’ SP Dis boards across the site feeding lights and basic power - in case of supply interruptions. It seems that existing TP boards had SP circuits removed and installed into these boards, with a 3 position change change over switch about 6 years ago ir so. The positions are. Mains on, all off, generator on. The idea is that the three position switch is throwen to generator, isolating street supply and the generator is then manually started.
where can i find more about the regs governing SP generators and their integration into fixed TNCS systems please?
These 3 position switches also isolate and switch over the earths. I have looked inside...
My concern here is that in all areas there is always a TP Dis boards supplying TP and SP non essential circuits in the area. Isolating the earth in this way seems dangerous? We are also in a reasonably high lightning area, so if earth was isolated this could also impact any surge pritection - not that there is any yet ?.
Is earths like this common practice with fixed generators?
john
john
