Discuss Flourescent tube lights in Gymnasium in the Australia area at ElectriciansForums.net
1shortcircuit
A friend of mine has asked me to pop over and see why one of his fluorescent units is not working in the changing rooms.
The only information I have at the moment is that it's a double strip light unit and he's tried swapping them over with known working replacements and still no light.
There is no starter visible externally.
Am I correct in thinking that it's likely cause could be that the transformer has failed? Obviously I will check all terminations when I am there but my initial thought is that it is this as the unit has been in use for approx 18 months and now both tubes are no longer working?
Assistance very much appreciated.
Regards
1SC
:thumbsup
It's pretty rare for ballasts to fail especially in recognizable brand name fittings. I would just go along armed with 2 new tubes and starters. It could be a series wired fluorescent where if one tube goes down, both stop working.
More importantly, why you worrying about this on a Friday night? :)
chances are if there are no obvious starters externally, they maybe located under the lamp itself. However it may be a High Frequency fitting and therefore no starters at all.
If he has changed the lamps and still no light, i'd bet on the ballast. And rather than pee about changing it (unless its extremely easy and cheap) just buy a new fitting
Thanks for your replies guys, went to have a look this morning.
There are indeed no starters and no light. When I tested voltage on the suspect unit I got a reading of 230v going into the ballast and 12v out. I compared this to the unit opposite (3 in same room) and that had 230 in and 230 out.
As there are 3 matching units I believe the best course of action would be to replace the ballast on this occasion.
All I will have to do is find a replacement ballast. Are they easy enough to source individually? I took a couple of pictures:)
As it is in a changing room is there high humidity, and if there is, is the fitting suitable for the environment. as this may have caused the ballast to fail.
Thanks for the input Malcolm, There are a number of showers in these changing rooms however the suspect unit is the one furthest away and as far as I have been informed this is the only problem reported. Definitely worth reviewing though if problems persist in the future. Thanks:)
....There are indeed no starters and no light. When I tested voltage on the suspect unit I got a reading of 230v going into the ballast and 12v out. I compared this to the unit opposite (3 in same room) and that had 230 in and 230 out.
Please be aware that some ballasts have protection and shut down the output if tube ignition doesn't happen cleanly or fails completely. The ballast will reset itself when new tubes are fitted if it's of this type.
Regardless of the low output voltage my original advice still stands, try new tubes first or you might be unnecessarily replacing ballasts or even worse you could be sitting with exactly the same problem after you've fitted a new ballast.
Thanks for your input Marvo, sorry I didn't mention that I firstly swapped out the working tubes from the opposite unit and then also fitted brand new replacements and still not even a flicker from the suspect unit.
Thanks for your help, this area is completely new to me:thumbsup
Reply to Flourescent tube lights in Gymnasium in the Australia area at ElectriciansForums.net
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Good evening all Ive got an old truck 1990 that has always had intermittent starting issues whilst ive owned it.. As far as i am aware the...
Hi all, I have an unusual issue with a recent rewire I have just completed which I hope you guys can assist with. For background, this is a...
A few months ago, I replaced a T8 fluorescent tube that my late father installed, with another tube of similar dimensions. The lighting still...
