Discuss fluke 1652b in the UK Electrical Forum area at ElectriciansForums.net
hi just looking at the fluke as listed above, does and body know if it has rechargable battries on board?
im sick of changing them over in my megger!
best regards
mike
(any other opinions welcome ) )
No mate, it doesn't have rechargeable battery pack as standard. It can be used with AA rechargeables though, but they don't allow so much headroom before the MFT may display random behaviour, particularly as ni-cad and ni-mh cells have a high self-discharge rate. Most users report better stability when using good quality (Duracell or Energiser) alkaline AAs.
Many users report random behaviour of the Fluke 165x series MFTs caused by low batteries. This is experienced in many cases well before the 'Low Battery' warning indicator is triggered at 6V and appears in the display. The accepted wisdom is to test the battery voltage before the MFT is used and if the battery voltage is below 6.5V, replace the set of batteries with new ones.
To test the battery voltage:
1) Turn the rotary switch to the V position.
2) Press F3 to initiate the battery test. The voltage display will clear and is replaced by the measured battery voltage in the secondary display for 2 seconds before returning to the normal voltage display mode.
Reply to fluke 1652b in the UK Electrical Forum area at ElectriciansForums.net
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Hi folks. I'm having a PV system installed with a 5KW Amasstore GTX5000 Battery. This comes with a critical load output. I have the spec sheet but...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi Guys & Girls, It's been a while, hope everything is good. I have an issue that's proving to be a bit of a head scratcher. Please bear with...
