Discuss Foreign flags and foreign fittings in the UK Electrical Forum area at ElectriciansForums.net
Lucien Nunes
Mentor
If you've read my posts and noticed that I'm flying an Estonian flag, you might also spot when it changes to Italian this weekend. You might also have noticed over time that I am quite keen on certain European wiring materials and methods. For a bit of fun I'll post a few things that I like in this thread as I travel. Most countries that have their own regs have something to offer that is better or easier or safer, unfortunately you can't just pick and choose the features to create a gold-standard system as some are incompatible. E.g. I like Schuko plugs and I like 32A ring finals, but the two can't be used together.
To start us off, here in Estonia the wiring is standard European fare with a German basis. I went shopping and bought some materials, here are some examples of things you would not find in the wholesaler in the UK. Can you see anything here you would use to wire a cooker? (not that I wire cookers)
JB wiring demo coming shortly...
No, I'm working, but I get to move about. Last weekend I popped back to London, previous one I was in Helsinki with G/F etc.
I'm going to go with the flex (can't quite tell what size it is) the 5pin plug and socket and 3x 20a bottle fuses I think, and perhaps the connectors and adaptable box too?!
That isn't flex they are solid core conductors.
Yes, no, sort of. The 5-core 2.5mm² cable is KH05VV-F, bog standard general purpose interior cable used where T+E would be used in the UK but available as 2, 3 & 4c +E. Solid core up to 10mm. NYM-J also bog standard and same principle, but heavier construction.
Then there's the Perilex 3P+N+E plug. These are sometimes said to be a bit old hat now but still fully compliant. In the UK we don't have a 'domestic' or 'light commercial' 3-phase plug but Perilex is exactly that. You wouldn't want to a 16A CEE17 socket sticking out behind a freestanding cooker because you'd never get it against the wall, but Perilex is just the job with a flush-mount socket and right-angle cable entry on the plug. Want to clean behind the cooker - unplug and move it out of the way. Pretty reliable at 16A (equates to 48A single-phase) and a doddle to wire with 2.5mm² compared with wrestling 10mm² into back boxes. As with Schuko sockets the contact base goes in first and gets wired, then the front plate is just a cover. You don't have to flex the cables to get access to check terminations etc. Of course you only get these luxuries with a 3-phase supply to your house, and that has drawbacks as well as benefits.
why do you prefer Schuko to BS1363
I didn't say that. I like them both for different reasons, they are very different connectors. Schuko has the great advantage that any decent socket and plug combo will actually carry 16A all day long in a way that BS1363 can't quite be trusted with 13A, thanks to the soppy little heating element built into every plug. If you don't need the fuse, it's a nuisance; we've got BS546 15A as an unfused alternative and I like that too, but Schuko (and as George says, if you care about polarisation which I usually don't, CEE7/5) is neater and comes in a much greater variety of flavours.
Seems like it's just me that fancies the "ribbed" conduit thingy which must have many uses...some of them electrical related...
is the ribbed conduit thingy an expansion joint for plastic conduit?
Reply to Foreign flags and foreign fittings in the UK Electrical Forum area at ElectriciansForums.net
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
