Discuss Form Filling in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
daver
Hi guys & ladies
Pardon my ignorance. I have recently qualified and just completed my first job. This is the one Elecsa are coming to inspect. Meters went in yesterday, so Monday is test day for 8 flats. I am using Elecsa forms, which seem condensed compared to NIC ones. But here is the question
Incoming mains to 100A fuse to Meter and then switch.
My tails to a 60947-3 Fused Isolator
Up to Consumer Unit with 100A Main Switch and 2 63A RCD's
So obviously on form, you have Primary Supply Overcurrent protective device
Then Main Switch or Circuit Breaker
I have 3 items, so do you double up in the Primary box and list both ???
And then on the main Installed Circuit Details. Would you use 2 sheets, ie 1 for each RCD, or would you list them all on 1 sheet and draw a line between them.
When I did my 2391, we did not form fill for split load.
Be gentle on me.
Thanks in advance.
Hey Dave.
Your primary supply overcurrent protective device is the DNO fuse in their cut-out i.e BS 1361 type IIB 100A.
You only have the one board so one sheet is fine. list the circuits on your first RCD plus any spares, then Put RCD and then list the circuits on your second RCD plus any spares.
Cheers:D
Elecsa forms are based on the forms in 7671.
NIC ones contain columns for additional items that THEY want you to record.
Reply to Form Filling in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all I have been pulled up by Napit, not by my regular inspector. Used rcbo's on a rewire (usually do). Filled out cert to reflect this, with...
Its time I bit the bullet and got some proper certification software, I've used my own forms for ages now which I spend pre-filling everything in...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
