Discuss Fuse Identification in the UK Electrical Forum area at ElectriciansForums.net
S
solavie
Doing some work on a flat. Moving a light. What fuse type is in the picture. There is no marking on the fuse.
Thanks.
Sorry but I don't see any fuses.
Yea I'd go for 3871 also the markings should be on the side of them.
so was kon-tiki, but it crossed the atlantic.
Crabtree c50 3871 m3 if I'm not mistaken. One of the worst boards you will ever have the good fortune to work on.look at the live parts on that baby!
Yes it is a nightmare. There was not MET or bonding to gas or water. Aware it is switched on. But I switched it off when taking the l cover off and on (Guess what it is METAL) as there is a great risk of shock from the top of that box. It uses the conduit as the cpc. tested the continuity. The light was in the bathroom, so had to cross bond everything there as well. Lot of work has been done there, new kitchen and bathroom but they forgot to modernise the electric. No Rcd
Meant MCB (not fuse). This is 3871 from your replies.
Avoid Flats
but the an-tiki. modelled on the same design, crossed the atlantic.
They have different kA ratings depending on age of the particular C50 mcb which is identified by the colouring of the writing on the mcb either white or yellow writing. I can't see what colour yours is from pic
Im sure the colour defined what type it was not the kA rating
Which identifies the KA rating they are 3871 type 2 the colouring of the lettering is to identify the KA rating I have the memo from Crabtree technical if you want a copy
im fine i have my own technical info thanks, but ive seen white and yellow crabtree breakers side by side both stamped with 4.5kA, white was type 2, and yellow type 3. :)
Reply to Fuse Identification in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm adding American muscle's halo fog lights to my 2006 v6 mustang and am looking for a good place to connect the positive side to power the...
Two questions: 1. I’ve had a bulb in the hall turn black with some white powdery deposits (see photo), whats caused this, guessing i should get...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Hello Shop with a 100A main fuse LED lights few amps max, cash tills, cash machine, roller shutter, auto door, nothing pulling much power but...
