Discuss galvanised steel in the UK Electrical Forum area at ElectriciansForums.net
the pict
Mentor
Whats best to get a good earth grind it off and re-paint or bolt to the surface, is galvy a good conductor ? trying to weld it would suggest it aint
\pict
zinc is actually a better conductor than the steel.
the fumes given off by galv when welding are poisonous, so dont breathe them in.The best way is to grind off the surface coating then after making the connection cover the area with cold galvanising spray to protect it from corrosion.
Cheers Guys, not goning to weld it just from experience welding is a pain in the ar££e just drill it out it was more a question of do I need to gring off an area surrounding the bolt head
P
No need to grind coating as regards conductivity. On a scale where copper =100%, steel is up to 15%, zinc 27%.
Why would you need to grind off a hot dip Zinc coating (galvanised coating)?? Non conductive paint, powder finishes and clear coat finishes Yes, but a highly conductive hot dip Zinc coating NOooooo!!
to grind or not to grind,one for the tester I think, might rig it up today and see what impedance readings I get on the coated surface, got my annuall NICEIC visit today I will run it past him, although I think I know what the answer will be, guesses anyone.
exactly.
Just one of those things, the place I was at they had you grind everything and I just got used to doing it, If they wanted to spend vast amounts on galv spray who was I to argue? Plus it came in handy at home.
My limited understanding always led to me believe in many instances, zinc dips were actually done to improve the conductivity of the surface...surely, as mentioned previously numerous times, the need to grind and re-coat is somewhat redundant. time could be better spent drinking a cup of tea?
couldn't agree more mate but if that's what the bosses want that's what you give em,ours is not to reason why.
Nope, Hot Dip Zinc plating is purely for it's corrosion protection properties of mild steel, and some other metals.
And by providing good corrosion protection, it helps to ensure good continuity of the bond in the future. An uncoated mild steel surface left after grinding is totally dependant on the zinc-rich paint to prevent it rusting, which would lead to failure of the connection. Paint is surely second-best to galvanising?
Reply to galvanised steel in the UK Electrical Forum area at ElectriciansForums.net
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hello fellow sparks, I’ve decided to go out on my own. Recently bought a little van and trying to get myself set up whilst keeping my costs as...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Hello and Happy New Year. It's not starting too well for me, excuse pun. Since Friday December 16th, The 2.4l Duratorq diesel won't start...
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
