Discuss Gauge Requirements in the UK Electrical Forum area at ElectriciansForums.net
stokes86
I have been looking around and used a calculator for this. I am looking to run 120v/100 AMP supply to a pole barn 175 feet and buried from the main breaker. What size and type of wire will I need? Thanks in advance.
Can anyone help me with this?
With the length and the amperage I would use THWN or THHN which is the same type of wire and the size would be #2 wire. I’m curious of why you would want just 120vac to the pole barn when you could install a panel in your barn and pull 100 amp 240vac service to that. It would also have to be in conduit which PVC is the cheapest. That’s a lot of work for just 120vac. Something to think on. Good luck
Thanks for the feedback. Only adding lights and a bathroom to the barn. Its used mainly as storage.
Reply to Gauge Requirements in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm a hobbyist without formal training. I'm looking to power audio/video equipment over several hundred feet of extension cords. I have 2...
Hello! My shop is currently on a single 15 amp circuit. Is like to upgrade it at the main home panel to a 30 amp. Do I just need to run 10 gauge...
Installing a 13K peak (10K running) generator 190 feet from the panel. The portable generator is housed in a shed at the end of the property...
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
