Discuss guidelines for a lamp in the UK Electrical Forum area at ElectriciansForums.net
hi guys
right looking for some help, im metal fab companys and looking making lamps from chain and other similar ,materials. thing the i need help with is what testing do i need to do to conform to regs????
also the buld holders i have bought don't seem to have a earth connection? is this normal of have i bought the wrong ones???
thanks for any help
you'd need them CE certified. there's loads of different regulations. bloody minefield. time to get your company's pencil necks off their arses.
It must meet the Electrical Equipment (Safety) Regulations 1994. You would have to compile an EC Declaration of Conformity (DoC) along with technical documentation. If you are producing a unique or innovative item which may not fall in line with relevant British Standards you would have to satisfy its safety is no less than suggested in these Standards. After all this stick on a CE label. Simples.
thanks, been reading up on it and some people are suggesting that as long as the electrical parts have a ce mark on them thats fine? and as long at i use 3 core wire so i has and eath that fine? and get i pat tested that will bring it to within british standards?
PATesting it will not bring it into line with British Standards but I agree it maybe just the electrical components or equipment which are subject to conformity.
ive been looking at other companies that sell stuff a bit like mine and non of them mention and certificates or ce marking? its job to know what todo ive read the regs and i think my lamp ive made follows tthere guidlines
hi guys
thanks for any help
You can get them with or without the terminal. Depends if you require it or not. Class 1 will and class 2 will not.
Reply to guidelines for a lamp in the UK Electrical Forum area at ElectriciansForums.net
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
