Discuss hardwiring cooker straight into 45 amp isolator in the UK Electrical Forum area at ElectriciansForums.net
A
aaroncrisp1983
If I intall a 45 amp cooker isolator inside the kitchen cupboard can I come straight out of that and hhardwire into the cooker? So I dont have to install a cooker outletplate as there not.much room.behind.
As far as I know there is no regulation saying you absolutely must fit a cooker outlet. It is more of a convenience thing for should you need to change the cooker. What kind of cooker is it? Is it a unit that fits in the kitchen units with a seperate gas hob? If so you'll probably find it comes with a plug top. Chop the plug off and fit an unswitched fused spur. Doesn't take up much room
I wouldn't chop the plug off, manufacturers are tight as a submarines door! They'll do anything to void the warranty even for cutting the plug off!
If you've the space for an isolator switch in a cupboard, you've space for an outlet plate. Iso's exist for a reason, especially for domestic cookers. Whilst there's no specific regs that require you to have an OCPD > ISO > OUTLET arrangement, it's been done that way for decades for very sensible reasons. Namely, that if the darn thing catches fire you want to be able to turn it off straight away without having to spend five minutes ploughing through coats and vacuum cleaners to find the consumer unit under the stairs. Therefore, if you have an ISO, you also want a more convenient means of making a connection to it - hence a cooker outlet plate (which doesn't have to be fitted behind the space for the oven, it could be another cupboard away).
yyes you can do it, but I would follow Rocks advice above this reply for the reasons he highlighted.
I was going to hardwire the cooker into the isolator which will be in the cupboard and plug the hob into the isolator which has a socket on. I think this is ok.
it's OK, but the thing that has not as yet been mentioned is this:
when and if you want to change/service the cooker, that will mean isolating at the CU MCB in order to disconnect from the isolator,which is only single pole isolation, whereas if you had fitted a cooker outlet, all you need to do is isolate with the cooker isolator for safe isolation of both L and N.
I was going to hardwire the cooker into the isolator which will be in the cupboard and plug the hob into the isolator which has a socket on. I was not going to cut the plug of the hob. I was just going to make a hole for it.
yes we understand aron, however we have given you our advice mate and you will have to decide what to do, I think you have made your mind up anyhow by the look of your replies so we need not reply anymore with advice on this subject.
Im confused here. I thought it was a case of the cable comes out of the isolator and feeds straight into the cooker therefore bypassing the "elephants nose" as the OP felt there was not enough room. This to me seems ok not best practice but no regs stating otherwise. Now we have a hob being plugged into the socket alongside the 45amp dp switch. All seems like a bit unnecessary and untidy now rather than just fitting it all where required. Remember a job done right first time means you are not back at it three months down the line
i had myths in the wardrobe. a couple of mythballs sorted them out.
Reply to hardwiring cooker straight into 45 amp isolator in the UK Electrical Forum area at ElectriciansForums.net
Is this ok? 32amp breaker with a 6mm wire leading to fused cooker switch. This then leads with 6mm cable to hardwire point. Can i hardwire 2 x...
OLDBOY
O
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
Hi, can someone please advise on where if anywhere I may acquire an adapter to duct out this old Elica cooker hood. The hole is 150mm x 90mm and I...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
