Discuss Helacon connectors in the Electrical Tools and Products area at ElectriciansForums.net
They are not a bad price, I like the helacon ones because the holes are all in 1 line and fit in enclosures better, that's the only let down with wago/line equivelents, some good stuff on that website though thanks
Reply to Helacon connectors in the Electrical Tools and Products area at ElectriciansForums.net
I am looking for the connector for this rotary position sensor. The sensor is originally normally used for an EZ-GO golf cart as the throttle...
Been using Wagos since they came out, love them, but was wondering do you use them in poured resin submarine joints. Obviously if the resin had...
Hi, I have accidentally pulled a wire out of connector (believe it is a molex?) I have seen info about getting the metal part out of the connector...
We have had RG11 installed in some flats for use with Virgin/Internet. It should I think have been RG6 but the guy at Virgin was insistent it...
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
