Deleted member 85661
Hello guys and gals.
Not that long ago, we purchased a 200 year old grade II listed terrace property, which has a relatively large basement!
The problem I have is with the electric service cable which runs right across the back of said basement (in the air!) to the main fuse block, then meter etc. The cable appears to be in a very sorry state.
I took a video to show its condition (tried at least). I can't visibly see any exposed metal, but then I didn't want to poke it about!
Would I be right to say that this service cable should be replaced (or at least inspected), by the electric company (SSE)? If so and they said yes it needs to be replaced, who is liable for the bill?
If they did change the cable, would ideally not want a new one in the same position making the rear basement area, unusable. Would it be in my rights to tell them to route it out of the way. Its potentially a livable space (if done up and the cable moved!).
Appreciate I should be directing these questions to SSE or alike, probably, but trying to do a little research first and your thoughts on this would be most welcomed!
Bad service cable - YouTube - video of said cable.
Thanks,
Chris.
Thanks,
Chris.
