Discuss Help - LED light is flashing in the DIY Electrical Advice area at ElectriciansForums.net
Kestas
Hi. I have a wall LED lights at home. I can turn it on with one switch at the entrance to the room and turn off with other near the bed. Problem is when both switches are turned off, wall lamp is flashing every 30 seconds.
Connection diagram I attached.
Is it any solution for this situation?
The problem is that I have a wall lamp with transformer and LED module in it, so there is no way to use a different lamp. Still have no solution.
Easiest solution is to change the transformer if you can, is it a separate transformer that you can swap out?
Are these luminaries purchased with the led lamps, or have you added the lamps yourself?
I've tried to change the transformer, but it's not easy to find a replacement.
The luminaries I purchased with the led lamps,it's not possible to replace them.
I found a solution in internet from another guy: he offered to install a capacitor in 0.47uF/400V right before the transformer. Any ideas - is it right solution or not?
Reply to Help - LED light is flashing in the DIY Electrical Advice area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hello, I've installed a Monsoon Extractor Fan kit today, all is up and running and everything is working with the exception of the LED. When I...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
