Discuss Help !!! Main switch tripping in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sparky1966
Hi Everyone,
Sorry if I am being stupid with this ( its late and i'm very tired)
Still learning and have had a call from a customer that their main switch (not mcbs) keeps tripping everytime they plug in a hoover, heavy duty drill, microwave, kettle into the socket circuit (all the house sockets are on the same ring circuit - 32a type b 2.5mm cable). The socket circuit works with all other items plugged in ( tv, fridge etc)
It also trips when they turn on the shower which is on its own circuit (45a type b) 10mm cable.
I am presuming this is an overload problem?? without seeing it yet thats all the info i have.
Can anyone help me with this? Has anyone come across this before? Could it be something else?
I hope you can help
I would say that the main switch that they are reffering to is an RCD protecting multiple circuits. If so then i could be a number of things. The RCD would need to be tested first off to make sure it is working correctly.
a thorough test for leakage either on appliances or on the circuits. always difficult when you have an RCD/main switch for the whole installation. process of elimination . could be a combination of leakages taking the RCD above it's tripping threshold.
Reply to Help !!! Main switch tripping in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Woke up this morning and tried to turn on the computer (work from home) wouldn't power on, checked lights they worked fine. Went downstairs to...
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
