T
Toneyz
I see that the OP took my advice thenSee #7 and #18.
Discuss Help wiring a ceiling rose in the UK Electrical Forum area at ElectriciansForums.net
Not sure what you mean?Well done!
But are you sure about the switch and lights being on different fuses?
OK, but my original advice stands to have the installation inspected by a REC. You can find a list on www.reci.ie or www.safeelectric.ieNo catastrophe, it has worked!
Thanks for your help
Putting all three browns together at one terminal and all three blues together at another terminal done it
I even stripped backed the wires and put the earths together
Very pleased with myself
I never found the junction box
I broke a wire when replacing the switch, it surprised me that the switch and lights are on different fuses
@gaz_sparky
Yes, it was originally a one center light that got converted
Well done!
In the consumer unit, I flipped the switch which I thought done the lights and switch
Then I went to fix the switch
I done my usual scan with my current checker and unexpectedly it started to beep
I got my other current checker and that beeped too
I'm glad I'm cautious
So I turned off the mains switch, checked again and fixed it
Agree......but what's a a REC?OK, but my original advice stands to have the installation inspected by a REC. You can find a list on www.reci.ie or www.safeelectric.ie
Aye, a REC is a Registered Electrical Contractor, i.e. one registered with RECI (the Register of Electrical Contractors of Ireland - also operating under the name Safe Electric).Agree......but what's a a REC?
...….Registered Electrical Contractor?
The OP needs to get one in, for sure. Very inexperienced, going off the terminology and info given. Simple jobs can be just as dangerous as complicated ones.
Reply to Help wiring a ceiling rose in the UK Electrical Forum area at ElectriciansForums.net
