Discuss help with cat 5 please in the Home Media Centre Forum area at ElectriciansForums.net
000aces000
Hi
I'm in a dilemma I have relocated the master bt point which is ok and I have wired a cat 5 cable from there to a slave socket at the other end of the room and then from there I have wired a cat 5 Cable directly to the tv
As I was hoping I could hdmi 1.4 cables with Ethernet channel. Which will allow all my devices to be connected to the internet that way
Now can a cat 5 be directly connected to the telephone line or does it need to go into the router cheers
Hi
Are you talking about telephone services OR a computer network ???
I'm presuming you have a master BT point with two outlets? One for the phone and one for the comp network?
The one for the comp network has to go to the router that your provider gave to you.
You do have a router? Who are you with?
lmao.. I get the feeling you dont like cats...
nasty bitey scratchy things. even when in a pleasant mood the buggers' fur gives me hay fever. then they have the audacity to purr when i'm fighting to breathe. good training for rottweilers though.
You can buy "ethernet to ADSL" cables online for a cheap price. There Should be Cat 5 as standard and probably some cat 5E if you look around.
However, ethernet to ADSL is usually used for internet phones so I'm unsure if it can translate the signal you need.
Reply to help with cat 5 please in the Home Media Centre Forum area at ElectriciansForums.net
Running an Ethernet cable to my outdoor studio. I did this successfully before using cat 5 but cable severed. Run a new cable cat 6e. This cable...
I am wiring a garden room which will be a home office, customer wants wired ethernet points and wifi down there from the house router Its too far...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
