S
Simon Hall
Hi I've done a ring main R1 and R2 test all my readings are around 0.15 ohms apart from one which is much higher at 0.83 it is not on a spur it is part of the ring any ideas or is this ok thanks
Discuss High reading on a R1 + R2 test on a ring main in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Was your r2 the same as the others?Yeah all around 0.15 ohms
Reply to High reading on a R1 + R2 test on a ring main in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
