Discuss Horstmann 425 Coronet wiring question in the UK Electrical Forum area at ElectriciansForums.net
LeeF99
I've just fitted a Horstmann 425 Coronet to control an immersion heater. All it's doing is turning the immersion heater on and off a couple of times a day, so a very simple arrangement. I've attached a photo of how I've wired it in and I believe it's correct, but I just wanted someone to confirm that I have wired it in correctly. I should add that the immersion heater does come on and go off as expected.
Another question I have is, when the immersion is on, the top of the timer at the far left and right gets quite warm. Is this to be expected?
Thanks in advance for any assistance.
Regarding it getting warm - is it designed to switch the current you are switching?
slightly warm is normal. excessive heat could be due to a poor termination.
Reply to Horstmann 425 Coronet wiring question in the UK Electrical Forum area at ElectriciansForums.net
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
Hi - we have an inline heater for a vent system that appears to always be on. I believe the electrician may have wired it incorrectly with only a...
