Discuss How many cables can you have in each MCB in the consumer unit? in the Australia area at ElectriciansForums.net
HappyHippyDad
Hello,
Question number 2.
I didn't get shot down in flames with the first question so I feel able to ask another.
How many cables can you have in each MCB in the consumer unit and more importantly why?
This is not in order to try anything myself but I do want to try and have some basic knowledge before I start the domestic installers course.
Thanks..
As many as you want to mate, what can go wrong
YYYYEEEEEEEHHHHHAAAAA
Seriously though apart from RFCs in my opinion it's one MCB, one circuit, one cable
Usually
Sorry trev!
It's just it's such a novelty that I actually know the answer to something that I can't resist posting!
Next time I'll leave it a few minutes for everyone to make sarcastic comments ;)
And why only one? Is it because it just makes it very clear which circuit that MCB is servicing or is their some reason/physics behind it?
so we can get two 16 amp mcb,s and put one leg of the ring in each ,,,,that will keep one cable terminated in one mcb.....,,,,,,,,,,,,,,,,,,,,,,,,,,,,, not,,, found five 1,mm terminated into a 6 amp mcb once...good luck with the course feller...
But .... you can have a spur (radial) from the consumer unit in with a ring final circuit (RFC). So ... two for the ring plus one for the spur makes three in that mcb. Same goes for lighting radials.
Damn you beat me, I just saw a CU today with five 1mm in a lighting circuit, four 1 mm in another lighting, couple of normal rings, two 2.5 and one 4mm in another and a 6mm SWA and a 2.5 in another. All unlabelled!
Murdoch's post also reminded me of two rings joined into one ring but different ends from different cables joined together and two CPCs joined then linked to MET with the other two CPCs in another slot, rats nest wiring nightmare to identify and test.
in theory if you add the 2.5 and 2.5 mm cable together you can get 5mm cable which means you can also add a light onto the circuit with the spare 1mm ;)
Reply to How many cables can you have in each MCB in the consumer unit? in the Australia area at ElectriciansForums.net
Can you feed a consumer unit from another consumer unit, It would be supplied by a non RDC protected MCB. Is this allowed as I have always seen...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
C
Hello, I recently bought and moved into my first home, and I made an enquiry with an electrician about doing a like for like swap of electric...
coalminers crufties
C
