Discuss How to get a 41A oven working on a 13A plug...? in the UK Electrical Forum area at ElectriciansForums.net
I Knew it was going to be one of those days when my first customer couldn't understand why his 9.5kw standalone oven/hob kept cutting out because it was on the old gas ignition 1mm flex & plug. I showed him the how the cable was red hot and the plug half melted but, as usual in these cases, because "it had worked" for sometime I was expected to replace the cable and plug and he'd take his chances. I explained I couldn't do that (if you ask why I would suggest you put your head in an oven... a gas one.. 😏) and he'd need a new circuit putting in. To top it off, the socket behind the cooker was a spur and then spurred to the cooker hood 🧐
I'm assuming as the current would have been about 19-20A that is why the fuse didn't blow (have I got 20A to blow a 13A fuse right?)
Because he was reluctant to pay for a new circuit I considered whether replacing the cable and fusing the plug at 7A would work as a temp measure if he kept the power down (as 7A would protect the plug from setting fire?) but he didn't want to reduce the power ergo I ruled it out and said the only thing I could do is install a new circuit (with blooming concrete floor, typical).
Just interested in any thoughts from you lovely brainboxes 🙂
between 21ish and 26ish amps:
I quite agree. I'm just interested in theoretical views on whether upgrading the cable to stop it burning out & downgrading the fuse to 7A to protect the plug from setting fire, and lowering the oven usage to stop the fuse constantly blowing would work (in theory) ... or whether I need to sit out of the sun for a bit lol
Uhh.... users.
If I was told this I'd walk away from it, like, I'm not in the mood to be held responsible for a wacko setting his flat on fire and then saying it's MY fault for incorrectly wiring the oven, because... everyone knows someone like that will never admit it's his fault.
Pretty Mouth is right, this wouldn't work, the second after you leave you'll have the guy replacing the 7 amp fuse with aluminum foil or a nail.
There's only one way around this issue and it's creating a new circuit with proper wiring and breakers, not sure how exactly you do it in the UK but if I were to do this locally I'd had to run wires from the breaker box to where the oven is and add a second breaker there to wire the oven, in domestic environments there can't be sockets and plugs involved with currents greater than 32A.
I just LOVE the fact that you even have 7A fuses in your bag!
I have 3,5,7,10 and 13...most of the 13A ones have come from plugs where I have replaced them with 3 or 5...
but. in your particular case, no way!
Lol! yeh, I have a few. Although not as many 13A as you never need them! All FCUs come with 13A (for some reason) but I've almost always had to replace them for 3A (mainly) and occasionally 5A. I think we should start a petition for manufacturers to supply FCUs with 3A. Much more useful lol.
You're right Carolina, I think he would have changed the fuse. He was trying to pursaude me to do a fixitupa but I stood firm and, as said, explained I'm not going to be responsible for his kids deaths. It does amaze me how so many people aren't concerned with safety and give the "It worked before" line. I want you to be a cowboy and charge like a cowboy, but be one that's competent - is the impression I get 🤔
The customer would be quite correct to blame the fire on the electrician.
The electrician is a professional, and the customer is a fool. The customer has every right to expect the professional to leave the installation in a FOOLproof condition.
If you voiced concerns over possible “solutions” such as a 7A fuse, I can see mr customer replacing it himself, and then telling authorities an electrician did it.
CYA.
Did you take photographs? Leave him a written explanation, or at least write something down for your own records?
Reply to How to get a 41A oven working on a 13A plug...? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi, My current oven is hardwired to a fused connection plate with a 13Amp fuse inside and power switch. That is then connected to the MCB labelled...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
