Don't worry, it is not that funny and probably people have been shot for better jokes in the past.Can someone explain the joke to me.
Discuss How to test RCD when RCD is RCD protected? in the UK Electrical Forum area at ElectriciansForums.net
Somewhere on here I quoted a response I got from Daikin who specified type B RCD protection.The A/C units we got specified 30mA protection, even though fed in SWA, etc. They may not actually need it, but only sane option was to follow the manufacturer's instructions.
Not sure if it stems from EU markets where TT earthing is the norm?
It's not so much of a joke as a measure of the knowledge of some trades that dable in electrics.Can someone explain the joke to me.
Been thinking a lot about your comment. Shouldn't the cable that's being fed from the main board to the sub main be RCD protected?As above, although you have to ask about the nature of the circuit design and apparent lack of discrimination if this is so. Very few reasons to protect a standard sub-mains feed with RCD, even less if it's not a cascading system of design with variations on trip time.
If its necessary, yes. If not, no?Been thinking a lot about your comment. Shouldn't the cable that's being fed from the main board to the sub main be RCD protected?
In a commercial setting with cable methods in trunking or similar I can’t instantly think of any (although some may exist) - in domestic there may be a case if you have for example an extension sub board fed with a buried cable. However, you either protect the entirety of the sub board with an upstream RCD (which I’d suggest would be poor design) or you cascade the trip times - an S type (time delay) upstream and standard A types downstream.Been thinking a lot about your comment. Shouldn't the cable that's being fed from the main board to the sub main be RCD protected?
Usual reasons are TT supply or high current sub-mains where you can't achieve disconnection on L-E faults due to Ze and/or affordable end of cable Zs being too high for the OCPD.In a commercial setting with cable methods in trunking or similar I can’t instantly think of any (although some may exist)
Is it the type AC RCD protecting the type A breakers?Look carefully at what each device is.
Hint, they have a test buttonIs it the type AC RCD protecting the type A breakers?
Oh ffs how did i not see those!Hint, they have a test button
Don't concentrate on the finger or you will miss all that heavenly glory.Oh ffs how did i not see those!
Don't worry, I spent about half an hour the other day staring a picture of an FCU with the neon on before I realised the switch was off.Oh ffs how did i not see those!
You'd use a time-delay or adjustable time curve device, though. Having a higher current let-through makes no difference under an earth fault situation - you're in the hands of the gods as to which device will react the fastest. Hence my earlier post above where when we put some maths into the discussion it all becomes obvious - doesn't matter how many RCD's there are in a series circuit, they ALL of them will sense the same fault, so the only way to achieve proper cascaded protection under a fault condition is to graduate the times. Typically on the systems I work with I'll set primary upstream RCD/RCM devices to around 1A, 1S running through 500mA, 1S > 300mA 100mS > 100mA 100mS > standard 30mA RCBO (depends on what the system is, though, some final ccts can be 300mA on their own... )Usual reasons are TT supply or high current sub-mains where you can't achieve disconnection on L-E faults due to Ze and/or affordable end of cable Zs being too high for the OCPD.
But typically in that case it would be a higher current delay RCD to be selective with final circuit protection, and once you have an RCD feed you get in to issues of trouble with N-E faults if not neutral-breaking RCBO in use, etc.
Most likely legitimate reason for two 30mA in series is an RCD socket fed from a typical domestic supply. You could argue such a socket is not necessary, but you might want one just for high risk areas where you don't quite trust one RCD's reliability.
Basically you'd only do it if you had to, as it introduces lots of complexity!Been thinking a lot about your comment. Shouldn't the cable that's being fed from the main board to the sub main be RCD protected?
Okay I see. Putting a time delay RCD upstream and another RCD in the sub main board just to put in a garage supply with a few sockets and 2 lights seems kinda nutty.In a commercial setting with cable methods in trunking or similar I can’t instantly think of any (although some may exist) - in domestic there may be a case if you have for example an extension sub board fed with a buried cable. However, you either protect the entirety of the sub board with an upstream RCD (which I’d suggest would be poor design) or you cascade the trip times - an S type (time delay) upstream and standard A types downstream.
If the wall parts were > 50mm deep OR the trunking was metal and earthed, and the attic parts were entirely visible and couldn't be construed to be "buried" then I'd say No, otherwise Yes.Okay how about this scenario - you put a sub main into your extension to supply a newly built extension that has equipment with a fairly decent load. You supply it with 10mm flat T+E and that cable is running through the attic, contained in trunking up the walls. Does this supply cable need to be RCD protected
So what cable would you say would be a good idea to stop the need of RCD protection? Maybe SY?If the wall parts were > 50mm deep OR the trunking was metal and earthed, and the attic parts were entirely visible and couldn't be construed to be "buried" then I'd say No, otherwise Yes.
The construction of the wall also comes into it, if metal then Yes.
The most likely answer in the real world is that RCD protection would be required for that scenario and hence choosing a different cable for the job might be wise.
SY (and CY) is not to any BSI standard so its use is frowned upon for fixed wiring. Even for moving machinery there are limited use-cases as often it is not UV tolerant for outside use, etc.So what cable would you say would be a good idea to stop the need of RCD protection? Maybe SY?
There is also a point where poor existing design in terms of selectivity is just not worth fixing. Here a garage fault will probably trip both RCD which is inconvenient, but maybe tolerable if that is not likely to introduce other risks. An obvious example is a garage workshop being plunged in to darkness with sharp tools, etc, all around. There you might decide to put in emergency lighting as a better solution as even an external power cut becomes less risky.It just feels a bit much to have to put a new time delay RCD into the main consumer unit. Might even have to change the board if there isn't enough ways!
Reply to How to test RCD when RCD is RCD protected? in the UK Electrical Forum area at ElectriciansForums.net
