Discuss Im putting in a new transformer for a halogen light and extractor in the UK Electrical Forum area at ElectriciansForums.net
chuckle
I am putting in a new transformer for an extractor fan/light and I thought I had finished but the fan works ok but the light doesnt. I have put in new bulb.
I think i must have wired incorrectly
If this is a "Showerlite" or similar extractor/light then the lamp holders are prone to failing, especially if run with a too high power lamp (if I recall, they are meant for 20W lamps) or if the lamp has been on with the extractor not working.
Another possibility is you have fitted an LED lamp but a transformer not designed to drive LEDs.
Were you sure the transformer was actually faulty before changing it?
Thanks mate, you raise many points. I will do some checking. I just assumed the transformer was not working as I changed light bulb and it still didnt work. I tried both anew led light and also a new halogen
Reply to Im putting in a new transformer for a halogen light and extractor in the UK Electrical Forum area at ElectriciansForums.net
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
