Discuss Industral cable ties in the UK Electrical Forum area at ElectriciansForums.net
DuaneMHunt1976
Am at a factory just filling in time driving
And they have two guys installing emergency lighting
And using cable ties even in a main walk way
Dose industry not have to bother with using metal clips on exits
NB I don't think it matters much as all the rest of the wiring is like that any way
should use metal ties/fixings. BS7671 applies to industrial as well as domestic. if cables are installed on tray or in basket, though, the tray/basket is the support.
I would caution against that approach as under fault conditions the cables are very likely to break free from the cable ties and potentially collapse. Often people use stainless steel for every third cable tie - although this is often seen with fire alarm it should be done more generally! Or with an SWA it could be cleated to the tray instead of cable tied.
I would be interested to know the percentage of people who cleat SWA to basket or tray. Daz
I can see how singles would jump under fault conditions due to electromechanical stresses, but multicore cables wouldn't, would they? (where all the currents cancel out within the cable).
(Not that you shouldn't cleat them properly anyway...: catalogue)
The individual cores of the cable will still repel under fault conditions. I've seen vids of a large multicore basically exploding on a test rig.
Reply to Industral cable ties in the UK Electrical Forum area at ElectriciansForums.net
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
Hello Couldn’t find anything in the forums on this and thought I would have… Large warehouse, minimal power circuits, two or three lighting...
5K
Hi all, Would like some advice on the below. Context: Rural French domestic installation TT system Earth rod is situated inside the property...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
