Discuss Inspection Schedules in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Under what circumstances would a single PIR or EIC have more than one Inpection Schedule?
Thanks for your responce.
Under those circumstances I normally issue a test sheet for each board, but only 1 inspection schedule. The inspection schedule does not include any identification of what it is for and therefore I assume it applies for the whole of the installation covered by the EIC or PIR. Am I wrong, and if so how do I indicate on the Inspection schedule what it applies to?
Post Note
Interestingly, I've just been reading GN3 and I quote "The certificate is only valid if accompanied by the Schedule of Inspections and the Schedule(s) of Test Results"
So I'm begining to think only 1 is necessary after all.
Reply to Inspection Schedules in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
