Discuss install 10 electric shower (8.5kw) in one hotel in the UK Electrical Forum area at ElectriciansForums.net
Hi i would like to know if is possible to install 10 electric shower (8.5kw) in one hotel if is possible what changes do I have to make to the general electrical distribution board
Thank you
i just need a diagram and the modification
jean-marc. forgive me if I have the wrong end of the stick here, but it seems from the question above "I just need a diagram and the modification" , that you intend going ahead with your plans regardless of the advice given so far, is that correct?
I ASKED FOR ADVICE'S BUT NO ONE IS ABLE TO GIVE ME ONE
I NEED TO KNOW WHAT TO DO SIMPLE IF YOU CAN HELP YOU WELCOME IF NOT THAT FINE
You have been given the right advice by Members, you need a survey by both the DNO and a qualified Electrical Contractor, if you choose not to agree with the advice, and go ahead regardless, then on your head be it, oh and stop shouting,
so you're planning on installing a total load of 350A onto what is probably a 100A supply. buy a pack of BS1361-II fuses or speed dial your local DNO.
Reply to install 10 electric shower (8.5kw) in one hotel in the UK Electrical Forum area at ElectriciansForums.net
Hi all, A few months ago we had a Triton Martinique 8.5kw shower installed. We've noticed that the temperature seemed quite low. Its what I'd...
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
Hello, I have a customer who is looking to replace their electric shower. There is equipotential bonding connected to the cold feed. I’ve not seen...
Hi everyone My mira power electric shower is not doing anything when i press the power button. There is no led lights to check on the unit to...
Hi, just hoping for a bit of advice. When I travel abroad (Europe, predominantly Spain/Cyprus) I usually take a single travel adaptor and a UK 4...
