Discuss install 10 electric shower (8.5kw) in one hotel in the UK Electrical Forum area at ElectriciansForums.net
is 80A FROM EDF NORMAL...I come across this all the time. The answer is generally no, but as pete999 says it needs a survey by competent person.
If you only have one phase then I would recommend no more than 2 but even that depends on the loading in the rest of hotel.
jean-marc. forgive me if I have the wrong end of the stick here, but it seems from the question above "I just need a diagram and the modification" , that you intend going ahead with your plans regardless of the advice given so far, is that correct?i just need a diagram and the modification
You have been given the right advice by Members, you need a survey by both the DNO and a qualified Electrical Contractor, if you choose not to agree with the advice, and go ahead regardless, then on your head be it, oh and stop shouting,I ASKED FOR ADVICE'S BUT NO ONE IS ABLE TO GIVE ME ONE
I NEED TO KNOW WHAT TO DO SIMPLE IF YOU CAN HELP YOU WELCOME IF NOT THAT FINE
so you're planning on installing a total load of 350A onto what is probably a 100A supply. buy a pack of BS1361-II fuses or speed dial your local DNO.I ASKED FOR ADVICE'S BUT NO ONE IS ABLE TO GIVE ME ONE
Which peteTHANK YOU PETE I THINK THE SAME
turn your caps off. (it's a magic button left side, next to "A". says caps lock on it)THANK YOU PETE I THINK THE SAME
!OK THAT FINE I WILL INSTALL A CENTRAL HEATING SYSTEM
THANK YOU ALL
Ummm what?OK THAT FINE I WILL INSTALL A CENTRAL HEATING SYSTEM
THANK YOU ALL
Reply to install 10 electric shower (8.5kw) in one hotel in the UK Electrical Forum area at ElectriciansForums.net
