Discuss IR testing with remote RCCBs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
cambria
I know RCCBs can be damaged by IR tests but what if the remote RCCB is switched off and IR test just performed between line and neutral connected together and earth, would that still cause damage and if not woud it give a valid reading ? I've got to test an installation with 40 remote RCCBs and not looking forward to going to each one and disconnecting them to do IR tests
I am not certain about this so someone is welcome to correct me.
I think it it depends on the reason why you are doing the tests - if it is for a PIR, with no agreed limitations, then yes no shortcuts. But if it is for a less formal checkup where time is money then AFAIK soft testing them at 250V with L and N connected in one croc and the CPC in the other would allow you to identify circuits that were definitely OK with respect to insulation to earth and others that would need further investigation; and so could save quite a bit of time. Depends what the client wants and agrees to.
Reply to IR testing with remote RCCBs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Hi everyone, I'm nearly on my AM2 test and really enjoy the industrial side of things so I thought I'd learn by asking. I recently came across...
