Search for tools and product advice,
Discuss Is there an issue with connecting 2 transformers together? in the UK Electrical Forum area at ElectriciansForums.net
M
Misshazhard
Hi all
Need to connect my cabinet kitchen lights. Already have the feed from the switch. I have 2 transformers that feed 3 lights each. (They came as part of a package so the transformer is rated to power all 3) Can I simply connect the feed from switch into 1st transformer connector block and then take the feed for the 2nd transformer off the 1st transformers connector block or would it be preferable to make the connections in a junction box instead? I don't see any issues with connecting directly to the terminals supplied by the transformer as surely it's no different to connecting them in a junction box? If there s an issue with this can anyone explain why?:sad3:
Reply to Is there an issue with connecting 2 transformers together? in the UK Electrical Forum area at ElectriciansForums.net
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
