Discuss Is this safe? Would it pass ECIR ? in the DIY Electrical Advice area at ElectriciansForums.net
Adelaide
TL;DR
Just moved into a rented flat. Was not given ECIR by landlord. Are these wall sockets safe above hob? LL says last tenants never had a problem with it. Is ECIR compulsory?
EICR is compulsory for any rental domestic property in the uk.
further to that, the landlord is required to fix any dangerous problems (C1 or C2) within a reasonable time, normally 28 days.
Reactions: DPG
Reply to Is this safe? Would it pass ECIR ? in the DIY Electrical Advice area at ElectriciansForums.net
Another thread asked about two circuits sharing a common multi-core cable and regulation 521.8.1 was mentioned. A friend of mine has inherited...
Hi, after some discussion with electricians, does removing a 16A or 32A socket constitute safe isolation? I understand that removing the socket...
Hi there! While making my bed I managed to flap my covers around so much that it hooked around my light and ripped it clean out of the socket...
Is the Rented Sector Scheme a legal requirement to carryout EICR's on rented properties. I can not see why there needs to be another scheme to...
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
