Discuss Isolation and switching in the UK Electrical Forum area at ElectriciansForums.net
I have a question regarding isolation and switching arrangements.
I want to work out what would work best within the regulations regarding splitting a new 200a TPN PME supply to serve flats above and a shop below.
my initial thinking new 200a PME supply - Trunking above feeding a new ryefield giving me x2 100a 3 phase supplies. (2x100a 3 phase supplies)
I would then have a x2 100a un- fused isolators for the shop and flats
*will i need an isolator between the Ryefield and the service head
*does the above sound feasible?
Sounds like you are being the BNO. UK power networks have a good guide on this as I have been in a similar situation. Make sure you are in contact with the DNO and what their requirements are. Some DNOs may ask for a 3 phase isolator before the ryefield. If its a small install you may get away without one. I fitted switch fuses to my risers.
Reply to Isolation and switching in the UK Electrical Forum area at ElectriciansForums.net
Need some advice, I have 7 static caravans to connect which need to be connected via TT 1. All the vans have a 30ma RCD main switch internally...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Evening, I've been asked to install a supply to a sprinkler system in a new installation that must be separate to the building electrical...
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
