Discuss Isolator switches ???? Neon in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
I’m just wondering is a switch with a neon is okay for functional switching only because I vaguely remember seeing that isolation switches like shower pull cords arnt ment for functional switching same as mcbs I might be wrong
I personally wouldn't use one for the very reason you stated, can you not use an ordinary 5 amp switch with an illuminated edge, after looking at table 53.4 I amend my statement
See Table 53.4 of BS7671, the standard you need to look at in this Table is BS EN 60669-1.
Yes, but no reply. And the OP may not understand the implications of your question, so i was asking sort of in another way.
My breath is bated.....
I have a Polo in my mouth... It's ecstatically happy...
As above, also minty breath...
i don't do mints or gum. I chew tobacco or cannabis leaves. something for the pc, "gender inept"to get their false teeth into . far out, man politically correct gander neutral none sex person.
always though gender was a male goose. now don't that have sexual connotations anyway?
Reply to Isolator switches ???? Neon in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
Good morning guys, I bought this neon sign for my cinema room to put above my arcade machines. I have the cinema controlled by Google voice...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
