Discuss Landis and gyre e110 generation meter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
powervan
Lads this meter has 2 readings? ( not seen it) which is generation reading! Wots the other? Chap just asked me but never fitted one!!
Sounds like it's a version configured for registering reverse energy. The LCD screen cycles between a "t" value and an "r" value. Which one represents the generation reading depends on which was round it was wired.....However, if the meter is in a secondary generation position then one of the readings will be extremely low (reverse energy back to the inverter bank) and the other will be much higher (the actual generated energy). These dual-display 5235 meters are normally intended as an import/export meter at the primary/utility position but are used frequently in the secondary generation position.
Thanks for that client said he has only ever had 350 units on meter which i presume is secondary reading as inverta shows 5 times that! i will go and have a look (we didnt instal it) but im thinking meter wired wrong way round.thanks again!
Reply to Landis and gyre e110 generation meter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
We have 10 energy meter in that 4x of them are giving the negative reading. The events shown are two 1is Negative Power Element 2 Warnings & 2...
I currently have a 3Kwh solar PV system which was installed over 12 years ago and getting a very good FIT payment and I don't want to lose it! I'm...
4K
I'm an electrical engineer in training so please bear with me. Basically, a bank has ordered a second 500kw diesel generator and my job is to...
