Discuss LD2 FIRE ALARM IN HMO in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello,
Ive been asked to install a LD2 system and I've not put one of these in before etc I've checked the regs so I'm upto date on locations etc but not sure how to wire this system up.
Could you please advise on the below.
1) Radials to each zone incorporating smokes and sounders and knock offs.
2) End of line resistors etc etc.
3) Testing the circuits.
Any help would be good thanks !
depends on whether you're fitting a conventional system or addressable.
What you are describing is not an LD2 system. An LD2 system is the minimum legal requirement for domestic smoke alarm systems throughout Ireland. It would be wholly inadequate for a HMO though. Typically a HMO would be more similar to a Part 1 system.
It,s a fire tec ld2 it will be zoned to each floor.
it is a ld2 system
one detector in each room and kitchen heat detector also detectors in all halls with break glasses
What i need to know is do they require a radial to each zone then all tie up at the ld2 panel
with a conventional panel, each detector zone will be a radial with EOL. same for sounders, separate radial for each sounder circuit, each with EOL.
I assume this is a Grade A LD2 system. Are you installing from a specification or are you designing as well.
Sounds like your installing a Grade A LD2 system.
Fire tec panels were discontinued as they dont meet EN54 2.4 2015.
But have rebadged Kentec panels as Fire Tec, they are available as 2 wire or conventional systems....any pictures of panel would help
Thanks Telectrix, Thats the info i was after. I looked about and seen all sorts of ways to wire. Thanks again.
I also have a other problem with high ZE fancy helping on that ?
need to know the earthing arrangements and what Ze value?
Reply to LD2 FIRE ALARM IN HMO in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi, I need to extend a fire alarm, the panel is a CTEC CFP 2 zone one and currently it has a couple of apollo alarm sense sounder bases/heads on...
4K
Hello People Our Enphase solar system needs to have the AC supply shut down via the fire alarm contactors local input output unit that has NO &...
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
