Discuss Learning electrical motors in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, I’m Not getting enough torque on startup to turn pump. Turns pump successfully maybe 1 in 6 times on startup and then fine at full speed. Currently connected in star as per plate, 400V. Ran from a three phase inverter. Should this be wired delta? Still very much learning.
A VSD then. if it says 230V in and 400V out then the motor should be connected star.
This is a bit more of an 'upmarket' VSD than the ones I have used, but on the cheaper ones there's loads of parameters to set up.
Most single phase Input vsd have a 3 phase output of 230v between phases.
therefore a delta connection at the motor would be correct.
Is this inverter being fed from a 400v 3 phase supply?
if not then what is it being supplied with?
Reply to Learning electrical motors in the Industrial Electricians' Talk area at ElectriciansForums.net
Good day to you. I need electrical drawings urgently and hopefully there is someone that can assist me. They are all for electrical trade test...
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Heeelp! I have an 11kW/21A motor which is attached to a hydraulic power pack. I have replaced the old panels with new, using the same star delta...
