Discuss LED bulbs burning out on same circuit as fluorescents? in the UK Electrical Forum area at ElectriciansForums.net
Just interested if anyone knows anything about this. I was chatting to someone in a wholesalers today and he said he had a lighting circuit feeding some LED fittings then a fluorescent then some more LED fittings, when he turns on the lights all the LED bulbs after the fluorescent blow straight away, he opened up the bulbs and the circuit boards were totally burned out. anyone have any ideas what might be causing this?
Harmonic Distortion. I duno, call the manufacturer of the leds and ask them. Sorry I'm not an expert in flossys haha
Well like I said, its not my problem I don't even know the guy but it sounded like a strange fault that ive never come across, all I can think is the ballast is maybe causing some kind of surge and I know the led bulbs are quite delicate, just thought someone might have come across it before but you obviously haven't but thank you soooo much for the helpful responses
Yeah, there's no question that the flossy is causing the problem so it's simple enough to fix...get him to take it out.
I have not known this problem either. I have put LEDs into some potentially electrically noisy areas such as lift cars with no problems.
I know it is not your job, but if the fluorescents did not have electronic grear then I would change them first. Failing that an oscilloscope or signal/power monitor to see exactly what is going on.
Yea, I don't think its got anything to do with noise, and its strange because its quite common to have fluorescents and LEDs on the same circuit as places slowly change them over, I agree that they must have an underlying problem they need to sort out
They're commonly called light-bulbs. Get used to it, because its not going to change.
Anyway, maybe the LED lamp-bulbs (as I prefer to call them to annoy all sides) don't like the lagging effect caused by the fluorescent control gear?
You really are STROPPY
I have a circuit in my house just as described and no worries so far ( 2 years) As for bulbs/lamps. My customers call them bulbs so, so do I. You sound like a trainee regurgitating what your lecturer is saying.
Reply to LED bulbs burning out on same circuit as fluorescents? in the UK Electrical Forum area at ElectriciansForums.net
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
Hi all, any advice would be greatly appreciated. Went to do some work at a factory unit on Monday ( changed 20 florries to LED battens and changed...
