Discuss Led circuit diagram in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
lukeysim
would this circuit work correctly with a 3GANG switch. I pretty much want to be able to control 3 colours (RGB) with the 3 switches.
thanks
slightly vague on info... need to know what fitting you got, how it works on colour change as they vary fitting to fitting, basically need instructions on fitting and if we had this im sure you'd have your answer anyway. I find RGB fittings with remote control for setting and altering the best then easy for customer and you for wiring.
Reply to Led circuit diagram in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
Hi everyone. I should start by saying I'm not sure I'm in the right place here (this isn't a householder issue - I'm making a Ghostbusters...
Greetings. I am new to this forum and I have a question regarding a relay that I am installing on a motorcycle wiring harness. What I'm trying to...
