Discuss LED Flicker in the Lighting Forum area at ElectriciansForums.net
Hi guys,
I have 2 wall lights connected in parallel to a dimmer switch. I've fitted 2 dimmable LED's which seem to work OK, however sometimes when dimmed they occasionally flicker. I've noticed that if I unscrew one of the LED's the remaining one never flickers under any circumstances.
Why do they flicker only when connected in parallel?
Regards,
Charles
We need some more details on the make and model of the dimmer and of the lamps, including whether the lamps are the same in all respects or not.
The dimmer is unsuitable for controlling LED lamps. You need to buy a dimmer switch or replacement dimmer module which is suited to controlling LED lamps. Take one of your LED lamps to a good electrical retailer/wholesaler and ask them to supply you with a dimmer of the right type and able to run only two LED lamps - LED dimmers have a minimum load requirement as well as a maximum load limit.
Thanks, I've tried an LED dimmer which works much better and will dim the lamps very much lower than I require, i.e. fully anticlockwise, although at this level there is a very slight flicker.
This has not really answered my question though, which was, why does the old dimmer work flicker free with 1 lamp but flickers when 2 are connected in parallel.
Reply to LED Flicker in the Lighting Forum area at ElectriciansForums.net
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
