Discuss LED lighting issue in the Lighting Forum area at ElectriciansForums.net
I have recently changed over to 6W LED fittings in my bathroom. They are fed from a junction box that has the incoming feed, outgoing feed to bedroom light, fan isolator and bathroom pull cord switch.
When switching on the bedroom light the bathroom LED's come on very dim and I'm getting a reading of 4V, the bedroom light is a dimmer so i wired that into a wago to see if it was the switch but still having the issue.
If someone could give me some advise or a resolution i would be grateful.
What exactly did you have in place before changing the lights to 6W LED?
Not, for example, low voltage 12V MR16 lamps, and you still have the transformer(s) in place?
They were 12v transformer lights in two circuits a total of 6 lamps, transformers removed and wired the 6 lights to one radial. As someone said above I think it’s induce voltage so I think I will install a Glowfix Load Regulator
Reply to LED lighting issue in the Lighting Forum area at ElectriciansForums.net
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
Hi, I was ironing and lost power to the bedroom and bathroom. All outlets and lights. I checked the box and reset breakers still no power. I...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
