Discuss Led strip to lighting circuit in the Lighting Forum area at ElectriciansForums.net
Many options available, depends on what suits the installation better.
If they are to be permanently fitted, then hard wiring would be my preferred method.
It depends on the installation. The LED strip is normally low voltage, so required an LED driver. If accessible (i.e. in a ceiling void, or in cupboard etc.) the terminals must be covered.
For temporary installations, they can just be plugged into the standard sockets. For permanent install, as James said above - hardwire into the lighting circuit.
Apart from 5amp sockets, there are many other possibilities depends on what suits the installation better.
For permanently fitting hard wiring is the perfect method.
For temporary fitting just put LED strips to standard sockets.
Reply to Led strip to lighting circuit in the Lighting Forum area at ElectriciansForums.net
Hi everyone I’m after some advice please. I’m installing some LED profile around a customers bedroom ceiling for some led strip to sit in and...
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
